New member Username: Jordan_1Post Number: 1 Registered: Aug-06 | Alright. I'm new to the car audio thing and was wondering if i could get a little help. I've been torn between 3 options. 1st option i get JbL speakers from a good friend for wholesale prices. 2nd options there is a store here in town that is trying to sell me memphis speakers and a dB sub street edge amp. 3rd option is that i buy from a site online where i could get a Rockford amp MTX subs and go ahead and get Memphis speakers.. but ive never had a system so if there is a better option im willing to spend around 500-600 dollars on a system.. considering i only have 1 working speaker in my vehicle ATM :P -- Thanks |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1685 Registered: Dec-05 | 1 audiobahn a800t, 2 AA assassins, 2 infinity components or Phoenix gold, 4 channel amp from any good brand and you're done |
New member Username: Jordan_1Post Number: 2 Registered: Aug-06 | Sorry, im like REALLY new to this .. whats a AA assassin?? and the 4 channel amp for just my normal speakers right? the audiopbahn for the sub and you saying 2 subs , right? --thanks |
Gold Member Username: CtmikeCt. Post Number: 1237 Registered: Feb-06 | assassins are the subs http://ascendantaudio.com/assassin_page.html the audiobahn is the amp http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13490 and the 4 channel amp is for the speakers |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1695 Registered: Dec-05 | yeah, is a good budget system |
New member Username: Jordan_1Post Number: 3 Registered: Aug-06 | one last question.. what is louder 2,4,or 8 ohms and which sounds best?? |
Gold Member Username: CtmikeCt. Post Number: 1257 Registered: Feb-06 | you mean as in the subs vc's? it doesn't make any difference except in the wiring options. |
New member Username: Jordan_1Post Number: 4 Registered: Aug-06 | aighty.. think im set.. thanks |
Bronze Member Username: RiskybPost Number: 44 Registered: Feb-06 | Actually wouldn't 2 ohms be the loudest but 8 ohms would sound the best? An amplifier is going to have less harmonic distortion with more resistance, but isn't going to be able to push as much power to the speaker. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1716 Registered: Dec-05 | you won't notice the difference |
New member Username: Jordan_1Post Number: 5 Registered: Aug-06 | When i get anough money what would i bee looking toward for upgrades for like subs and amps? |
