Why wont someone help me ....
Username: Firestomper25
Kenmore, Ny United states
please answer or guide me to someone or thing or place that can .. pleaseok how do i set up the amp to the hu so i can control it from the hu..... i know i need a cable that goes from my hu to my amp but what is it and where can i get it cheap..... and do i need a cappacitor if my over all rms is at max close to six hundred... but the peak will be around 1600 from the amp and 1500 peak (500 rms) from the sub ..... the amp i have is the kenwood ecxelon something... it a mono channel amp.... and i am only gonna have one 2 ohm dvc sub..... and im gonna wire to be a total of 4 ohm's.... i bought an amp wiring kit but dont know what goes where or how it wire it where.... and i dont want to do it wrong...... you can email me and sugar_daddy688@hotmail.com it would be easyier than here or use aim... me
Username: Rick_ross
Post Number: 274
go to a audio shop and pay them to do it since u dont know anything about it you will probobly mess something up if you try to do it
Username: Alias747
MN
Post Number: 1174
I will tell you why...
Because as soon as you open this thread you see one big messed up paragraph. It's annoying to look at and hard to read. On top of that you don't use any proper sentence structure, punctuation or capitalization.
Post Number: 8
Ok? And why are you such a grammer freak. why would it or even does it matter how i write anything. big frikin deal i just wanted some help.. you dont have to be rude about it. why are you just gonna be like that . i just dont understand. but anyways . i understand most of it now thanks to someone who was helpful and not critical like you
Username: Th3pwn3r
Chicago, Illinois U.S.A
Post Number: 40
LOL!
Username: Riskyb
Post Number: 43
ROFL
If I were you I would have a car audio shop do it for you. You could easily damage your amp or your headunit if you do not install it correctly.
This read isn't bad, just not many pictures.
http://www.caraudiohelp.com/how_to_install_a_car_amp/how_to_install_a_car_amp.ht m
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1717
Bro, don't get a capacitor... always see RMS ratings and brand, you must connect the remote to your HU.
