Pioneer DEH-235 please help
Username: Luge12
Ok, i threw away the wiring clip from the back of the cd player and was wondering what i could do....is there somewhere i can buy it or is the cd player just junk now?
Username: Leew
Ketchikan, ALASKA USA
Post Number: 482
You can get it here
http://www.partstore.com/ProductDetail.aspx?ProductSKU=5455469&ProductType=ACCS&ModelID=272496
Username: Luge12
just to make sure we're talking about the same thing i am talking about the clip that plugs in the back of it that the wiring harness connects to
Username: Illuminator
Post Number: 3859
That's the right thing.
It's called a wiring harness. If you check ebay you will DEFINITELY be able to find it cheaper. Be aware the harnesses aren't usually unit specific, they fit many of the Pioneer models made at that time.
