Silver Member Username: Crayola0Wisconsin Post Number: 470 Registered: Jun-06 | Any one know of a good amp that runs at 1/2 ohm. And if u have a dual 1 ohm sub and wire an amp to each coil it would have an impendace of one ohm right? |
Silver Member Username: FrkkevinLake Worth, Texas US Post Number: 364 Registered: Nov-05 | if it were a two channel amp.. mono block you'd need an amp to run .5ohm or 2ohm .. best bet for a 2ohm. It would be a lot cheaper. |
Gold Member Username: RovinTrinidad & T... Post Number: 8776 Registered: Jul-05 | yea it would def be easier 2 wire it up @ 2ohms & buy a 2ohms stable amp there r very few amps that could handle 1/2 ohms - mmats & old orion amps come 2 mind .... |
Silver Member Username: Crayola0Wisconsin Post Number: 473 Registered: Jun-06 | what do u think a 12" solo X could hit with 2000 watts in a 6 cu ft ported enclosure tuned to 35HZ. I know its based on instal but does anyone have any rough estimates? |
Silver Member Username: Crayola0Wisconsin Post Number: 474 Registered: Jun-06 | i really want an 18" solo x but idk. if i got one what amp would be better for the dual 1 ohm version. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14753 or http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14979 |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1579 Registered: Feb-06 | orion 2500d, i seen alot of people make a hifonics bxi2006d at .5 ohm and it didnt sounded bad and my friend got the 1600 at .5ohm for every day drivin and he never had a rpoblem, lanzar opti2000 atomic 5000 and atomic 2200.1 |
Silver Member Username: Crayola0Wisconsin Post Number: 476 Registered: Jun-06 | what do u think about the 12" setup above.. what do u think it would hit? |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 8473 Registered: Jul-05 | "what do u think a 12" solo X could hit with 2000 watts in a 6 cu ft ported enclosure tuned to 35HZ. I know its based on instal but does anyone have any rough estimates?" Tune it higher.... |
Gold Member Username: JakeyplaysbassSt. Louis, MO Post Number: 1357 Registered: Jul-05 | mmats makes .5ohm stable amps for ok prices |
Silver Member Username: Crayola0Wisconsin Post Number: 477 Registered: Jun-06 | aight what do u think i should tune it to and what do u think i would hit? |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4293 Registered: Aug-05 | 45 or higher. at least 145 if you know how to build a box worth a damn. lol |
Silver Member Username: Crayola0Wisconsin Post Number: 478 Registered: Jun-06 | lol... neva built a box in my life but i have a good idea how to. i want to be able to do somthing like this., http://www.realmofexcursion.com/videos/Kicker/solox18.5.wmv |
