Exact Rated Power
Username: Aman2005
Post Number: 261
Hello Buddies, I'm back with a question in mind and to get your help. Which amps are putting their rated power. I mean not under or overrated. If its 500WRMs, it should 500 WRMS. Not 525 or so or not 45. or so.
Los Angeles, CA USA
Post Number: 4577
jl slash series amps.
Username: James1115
Ct
Post Number: 6069
I would have to say they are underrated Chad.
Los Angeles, CA USA
Post Number: 4578
i thought since they have the regulated power supply so they won't put out more than their rated rms.
Username: James1115
Ct
Post Number: 6072
regulated power supply will allow them to put out their proper power at any impedence and voltage in their working range. The jl slash series amps themselves are underrated they do put out more power then they say. To determine watts you use the fuse ratings on the amp and the efficiency.
Los Angeles, CA USA
Post Number: 4579
see i always learn more stuff from you.
Username: James1115
Ct
Post Number: 6075
lol as do I from you:-)
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1627
damn chad you didn't know that.... lol"
Los Angeles, CA USA
Post Number: 4582
i knew the jl 1000/1 put out clean 1000wrms. also i was under the impression that the regulated power supply would limit the amp from putting out more power resulting in no clipping.
Username: Aman2005
Post Number: 263
Still here is nothing!! Isnt there any amp which puts out its rated power???
Username: Project6
Post Number: 9219
No and there will not be...there are no mandated standards as to how an amp gets its power rating and how they can claim these ratings. As long as they can show that it pushes out a certain number of watts per channel, it doesn't matter how they got thsoe readings as long as they can show that they got it.
Username: Aman2005
Post Number: 264
hmmm. ok I agree with berny, buy which amp pouts the power very close to their rated one?
There should be some
Username: Juliob
Post Number: 1648
you should buy an underrated amp, so if you don't have a good electrical system your amp can put the power you want for example if you need 800w rms, you get an amp with 800w rms at 12V right, so when your bass hits and the voltage drops, your amp will be putting 800wrms, got it??
Username: Aman2005
Post Number: 265
dear I dont want any amp, but i need some knowledge of the brands available in market.
Username: Aman2005
Post Number: 266
anyone else on this query???
Username: Juliob
Post Number: 1653
just read the ugly, bad, good list and you're done...
Username: Adddisorder
West palm, Florida
Post Number: 542
it shouldnt matter if an amp puts out a little more then its rated for say 25 or 50rms over because that isnt going to make the difference wether your sub blows or not.
