DD
Username: Atllefty12
Pinellas, Fla.
Post Number: 164
How much do the DD 9915 cost? also the 9515s?
Username: Basshead86
Google is your Friend, FL
Post Number: 4146
a lot. close to 900-1000
9515's can be had for roughly 600ish.
Pinellas, Fla.
Post Number: 166
yea its 599.00 for the 9515... i think im gonna do the mag lol
Post Number: 4148
Mag's are nice.
check out the Crystal Comp X. veddy nice also.
and cheaper.:-) if a little more power isn't an issue.
Username: Crayola0
Wisconsin
Post Number: 365
anyone know how much for the 15" DD 1000
Post Number: 4159
around 150 i believe
Pinellas, Fla.
Post Number: 171
hey muddy go on aim
Username: Crayola0
Wisconsin
Post Number: 367
are the dd 1000's sq subs or spl subs?
Username: Andysd03
Post Number: 336
they are both dd 9100 and 2500's are their SQ subs the rest are SPL and how much is a 9110? and how much is 9510 anyone know and how much is a 3510? iam thinking of geting one of those prob the 9110 since they are SQ and prob would beat my type X in SPL and SQ
Post Number: 4177
no. the rest aren't SPL.
they are all VERY accurate motors that play from below 20hz up to around 100hz or so.
the 9500's motor is prob the most accurate next to the 9100. and it would sound better than thew 2500 in the right application. but b/c ppl use them to compete for SPL by the masses you assume they are SPL subs. that is a uneducated statment.
Post Number: 4178
i would take a 9500 over an 9100 if price was an issue.
i would order it with less spiders dropping the Fs to 28hz.
i would then put it in a box 3-4 cubes tuned to 30hz.....and i would love to see anything come close to it in accuracy and loudness. for the price and wattage put to it. plus its durability.
Username: Andysd03
Post Number: 337
for now i got the type X whats a good tuning freq to tune them at so they would get low and still be fairly loud to 32HZ?33hz?28? for 2 10's
Post Number: 4179
35.
do you have a SSF on your amp?
Username: Andysd03
Post Number: 338
whats an ssf mean
Post Number: 4181
sub-sonic filter.
so like when ou put your subs in a box tuned to 70hz, you can set the filter to maybe, 40hz, it is goes that high, so you don't play all the way down past your box's tuning and blow the subs.:-)
