Silver Member Username: Logan__tille
Hamilton,
Indiana
United states
Post Number: 355 Registered: Feb-06
Posted on how do you remove from a disk without buying scratch remover? |
Post Number: 8568 Registered: Dec-03
Posted on Very fine sandpaper. 1000 grit. |
Hamilton,
Indiana
United states
Post Number: 374 Registered: Feb-06
Posted on are you serious??!! |
Post Number: 8588 Registered: Dec-03
Posted on What do you think a scratch remover does? It is nothing but very fine sandpaper mounted on a wheel that you turn to polish the scratched CDs. |
Silver Member Username: Camaro823
British Colu...
Post Number: 495 Registered: Jun-05
Posted on Dr.Cleaner or something like that, its a little handheld machine that polishes them up, saw it at EB Games |
Post Number: 9110 Registered: Dec-03
Posted on He did state that he does not want to buy a scratch remover...defeats the purpose doesn't it? How to remove a scratch without a scratch remover? LOL |
British Colu...
Post Number: 529 Registered: Jun-05
Posted on Whoa totally missed that part, anyways i'd still go get that its cheap and it works great |
