Stock Honda Civc Head Unit into another car?
Username: Caraudio
Toronto, Ontario Canada
Post Number: 553
Could i get the Stock Honda Civic head unit and put a sub woofer to it and put it in my CHrystler van?? Im going to try it but iwll it work?
Username: Illuminator
Post Number: 3826
Yeah, but it's going to be messy matching it to the van's harness...not to mention it has a different mounting system even if they're the same size. You'll have to use a LOC for the sub to work, I believe.
Username: Caraudio
Post Number: 555
I have to match the wires i dont ahve the plug that goes into the back of the Honda CD player would i have to go into my civic and cut that plug out and match teh wires??
Username: Hootz
Saskatoon, Saskatchewan Canada
Post Number: 198
You're better off just buying a cheaper aftermarket cd player. By the time you get that thing hooked up it's going to be a mess.
Post Number: 3829
Yep.
