Help with a sub
Username: Adam_s
Post Number: 46
I am going to be getting either an audiobahn a8000v or else the a8002v depending on the sub. So the help I need is that I dont know what a good 12" sub would be that can handle the 800 watts I am mainly looking for sql. thanks
Los Angeles, CA USA
Post Number: 4538
treo ssi 12
Username: Adam_s
Post Number: 47
how much does that ussually cost? and where can I get it from?
Username: Adam_s
Post Number: 49
bump
Username: Homercleeze
Post Number: 40
www.mobilesoundworks.com
or try your luck with ebay
Username: Adam_s
Post Number: 50
ok...another question is how does that compare to AA arsenal?? would it be comparable or is the treo going to be louder??
Username: Stnorris
Eldridge, IA US
Post Number: 1051
treo tsx 12, treo ssi 12, re se 12, aa arsenal.
