My cars dead
Username: Drsmith
Montana USA
Post Number: 119
got all my stuff installed today 2 12" cvx's RF t1000 BD turned it on, first bass note broke the damn box and a minute into the song my battery died and my amp wont turn on
so now I need a HO alt. but i dont no the difference between the amps what should i buy also how long does it take to get an alt from excessive amperage
Username: Pelona
Perres, California
Post Number: 1786
dam that fuken sucks!!! lol
Username: Troy81
Tavernier, Fl Us
Post Number: 857
hahahahhahahahahahahahhahahahaah, kill yourself, how did the box break?
Username: Drsmith
Montana USA
Post Number: 120
i duno i guess the guy that built it doesnt no anything but the top section came unglued
Username: Rovin
Trinidad & T...
Post Number: 8717
if u used LIQUID NAILS ur box will never open unless the wood itself tears apart - believe me i tried 2 open 1 of my boxes glued wit LN & the glue joints never come apart
when u contact ex amperage he will advise u which alt will work 4 u .....
Username: Drsmith
Montana USA
Post Number: 121
has anyone ever ordered from there how long do they normally take and is there anywhere else i should look for an alt
Username: Drsmith
Montana USA
Post Number: 122
bump
