Anyone know thier stuff?
Username: Djflipnautikz
Miami, Fl United States
Post Number: 14
Which alarm thats a two-way with a good immobilizer should i choose for my 2003 jaguar? Preference to clifford. and should i buy it online and take it somewhere? if yes, where to by it? i am also looking for remote start.
Post Number: 18
come on guys??
Username: Ruthless06
C-ville, Va USA
Post Number: 186
I have a viper 791xvr in my vehicle. You could get one of those for pretty cheap, and use a directed 556uw universal bypass module. i've never had problems with mine or any others i've installed.
As far as buying from somewhere I would recommend buying from someone and getting them to install it if install is included. Like at my shop all remote start/keyless/security the basic install in included. All other options like secondary+ sensors and extra labor like if you need a module for immobilizer system or a locking bypass module like for toyotas or a lot of newer chevys. A lot of shops like to charge ridiculous prices for install if it wasn't purchased through them.
Just my .02
