New member Username: BearcatsWinnipeg, Manitoba Canada Post Number: 1 Registered: Jul-06 | can anyone helpme out I just bought a new cool sat 5000 platinum and i need some info on it and maybe some keys to help me out. Any info on ths reciever is greatley appreciated.! |
Bronze Member Username: SikapetahiPost Number: 21 Registered: Jul-06 | heres real good advise buddy.Get your money back and wait till the new flash for FTA comes out because as is this units almost useless UNLESS you have no TV period |
New member Username: BearcatsWinnipeg, Manitoba Canada Post Number: 3 Registered: Jul-06 | ok the what is the best fta reciever to get then? |
Silver Member Username: Mybig_williePost Number: 220 Registered: Jul-06 | You have it. |
New member Username: BearcatsWinnipeg, Manitoba Canada Post Number: 6 Registered: Jul-06 | then why is the other guy telling me that it is useless? |
Bronze Member Username: Electro99Post Number: 77 Registered: Jan-06 | ok Roman return your 5000 cools@t if you dont wanna spend more couple hundreads bucks on other equipment witch probably not gona work or gona work not the way how you wanna see it or you gona spend so much time to set up everything right got some channels >>>> I think i know your nationality then forget to get channels what you think about>>> Good luck !!! |
Silver Member Username: Mybig_williePost Number: 221 Registered: Jul-06 | The way it is is usless for now.If and i mean if a fix comes it will work.You can buy a reader and card like in the other thread you got going.You see the extra price and hope it last but probably wont.Also you have to learn how to fix that card using the available software out there. |
New member Username: BearcatsWinnipeg, Manitoba Canada Post Number: 8 Registered: Jul-06 | ok so what is the best deal on fta. Like if I take it back what fta should I get that will give me the most out of fta? |
Silver Member Username: WaydownPost Number: 197 Registered: Jun-06 | electropunk is full of sh it, you need to keep the 5000 and spend a couple hunded bucks and get all channels |
Silver Member Username: WaydownPost Number: 198 Registered: Jun-06 | card reader 55.00 on ebay ,install it in your 5000.very easy to do,also you buy on e-bay a Plastic DN 102 unlocked card for about 175.00, then load with your computer bin 127 from (dsstester .com)into your 5000,this bin will AUX your Card Auto for you.200 dollars is cheap to spend for TV |
New member Username: BearcatsWinnipeg, Manitoba Canada Post Number: 10 Registered: Jul-06 | ok but what is the diference between this fta and another fta. Why do i have to pay ore money to get this thing to work? |
Silver Member Username: WaydownPost Number: 199 Registered: Jun-06 | co0lsat is the best right now because some of the others wont let you even put a card reader with them or you have to do card sharing over the net |
Silver Member Username: Mybig_williePost Number: 223 Registered: Jul-06 | Cause that thing has the ability to use a card where the others dont.There is no fix at this time for any fta receiver other than using plastic |
Bronze Member Username: BearcatsWinnipeg, Manitoba Canada Post Number: 11 Registered: Jul-06 | what is plastic anyway? |
Silver Member Username: Mybig_williePost Number: 224 Registered: Jul-06 | A plastic smart card. |
Bronze Member Username: BearcatsWinnipeg, Manitoba Canada Post Number: 12 Registered: Jul-06 | one other question is there any diiference betwween the 6000 and the 5000 cool sat. Like will it take the same software and is everything mostly the same or is one completeley opposite from the other? |
Bronze Member Username: BearcatsWinnipeg, Manitoba Canada Post Number: 13 Registered: Jul-06 | are plastics illegal |
Bronze Member Username: BearcatsWinnipeg, Manitoba Canada Post Number: 14 Registered: Jul-06 | on ebay there are recievers already installed with the card reciever for less would that be ok just to buy the cool sat with the card reader installed already? |
Silver Member Username: Mybig_williePost Number: 225 Registered: Jul-06 | YEP.So is installing a bin that decripts a signal.FTA is not free DN. |
Bronze Member Username: BearcatsWinnipeg, Manitoba Canada Post Number: 15 Registered: Jul-06 | ok so i should get one with a card reader in it and then what else do I need to get if ZI have the reciver and everything and i also have the card reader installed already? |
Silver Member Username: Mybig_williePost Number: 226 Registered: Jul-06 | You could buy one but you still need a card and a reader,unlocker,programs that clean and load,a file for the card.$200+.And it may not last. |
Bronze Member Username: BearcatsWinnipeg, Manitoba Canada Post Number: 16 Registered: Jul-06 | but it already comes with a card reader? |
Bronze Member Username: BjaltAtlanta, GA USA Post Number: 25 Registered: Apr-06 | Yes, plastics are illegal. Modifying your receiver in anyway to receive decrypted signals is illegal. |
Silver Member Username: Mybig_williePost Number: 227 Registered: Jul-06 | Comes with a card reader yes but not a card.175.00 extra and educate your self on the entire process of reworking the card.Dont make any mistakes or youll have a nice expensive ice scraper. |
Bronze Member Username: BearcatsWinnipeg, Manitoba Canada Post Number: 17 Registered: Jul-06 | weere can i get this card from were?ebay? |
Silver Member Username: Mybig_williePost Number: 235 Registered: Jul-06 | Why bother.By the time you get it and figure out how to program it,it'll be worthless anyway.Try going to al7bar,tk and read up on it there.Youll never get the info you need here nor do i think your going to understand it anyway. |
