Need help recording VHS to my jvc gr-d370
Username: Ktdid_23
DeBary, FL United States
I have an old home video that I am trying to get onto my mac from a VCR. I was told the easiest way for me to do this was to get my VHS onto my mindv. In my Camcorder manual it says to use a dv connector but I can't seem to find any VCR's that use this function. I do have a VCR that has output for the video and audio. Is there anyway I can plug in the cord (Red, White, Yellow) into the output and then plug the other end to the camcorder (AV) and then record it. I'm sure by reading this you can tell I need this explained in the most common terms possible. Any help will be greatly appreciated.
Username: Project6
Post Number: 8957
Does your mac have a video capture device?
Username: Ktdid_23
Yes it does
Username: Project6
Post Number: 8998
You can use an analog video capture device to connect your VCR to the mac.
Username: Ktdid_23
Where do I plug it in to the VCR? In the video out?
Username: Project6
Post Number: 9009
Use the VCR's audio/video output to Mac's audio/video input.
