All locals are down-----
Username: Ong_tu
Post Number: 132
Looks like they changed keys again. All locals are down-----
Username: Northman
Post Number: 160
Hope that its just a key change, not another CM. Look for keys & post here!
Username: Ong_tu
Post Number: 134
Yes been confirmed no one has keys yet!1
Username: Beba
Bayamon, Puerto Rico USA
Post Number: 19
key 01
DEE90B2287B4B633C3E43D59F9227C67
Username: Ong_tu
Post Number: 135
Where did you get that key from?
Username: Beba
Post Number: 21
ANOTHER SITE. DOES IT MATER WHERE????
Username: Djsmith
Post Number: 140
they are working ... thanks Daisy Duke
Username: Beba
Post Number: 22
ERROR
IS KEY 00
Username: Traxx
Swiftcurrent, Sask Canada
Post Number: 33
the key change is 00 not 01
Username: Djsmith
Post Number: 141
Follow these step by step instructions EXACTLY using your remote control.
Press MENU
Pres DOWN and highlight PARENTAL CONTROL
Press OK
Press DOWN to Second pin
Press 0 0 0 0
Press DOWN (select AUTOROLL OPTION)
Press OK
Select KEY CODE (make sure it is ON)
Select Dishnet Auto-roll (make sure it is OFF)
Press EXIT
Press DOWN and select NAGRAVISION 2
Press OK (you should see DISH NETWORK in the Provider ID)
Press DOWN to get to KEY NUMBER
Key number is now 00. ( if not, press the left arrow key, not the 0 button )
Press DOWN. (to key DATA)
PLEASE REFER TO THE TV SCREEN to PRESS THE CORRECT BUTTON TO PRODUCE THE LETTERS A - F
line 1 = DE E9 OB 22 87 B4 B6 33
line 2 = C3 E4 3D 59 F9 22 7C 67
Press OK to store the change.
Press UP arrow to KEY NUMBER
Press RIGHT arrow to change to key 01.
Press DOWN.(to key DATA)
line 1 = 43 0F 19 85 B7 80 14 63
line 2 = 1B 7A FC E3 F7 EA DC 2B
Press EXIT several times to exit all MENUS. WATCH TV.
NOTE: Both keys must now be correct for this to work.
Please make sure the keys you enter are EXACTLY what is written on this instruction sheet. If you enter a key in the WRONG position, IT WILL NOT WORK.
Username: Jj1
Post Number: 22
Daisy, Keys does not work.
Username: Beba
Post Number: 24
THEY WORK FOR ME AND OTHER PEOPLE TOO I MADE A MISTAKE I POSTED KEY 01 AND IT WAS 00. SORRY!!
Username: John_c
new keys are working. thanks daisy
Username: Hotwing
your new numbers do work..work on key oo..thank you daisy
Username: Goodguy
Post Number: 14
Keys work for locals, thanks Daisy
Username: Jj1
Post Number: 23
daisy, now it worked, I put it in 00 not in 01.
Username: Beba
Post Number: 26
SORRY FOR THE MISUNDERSTANDING!!!!!
Username: Ong_tu
Post Number: 137
http://www.dssrookie.com/forums/sate...tml#post561052
For keys
Username: Jj1
Post Number: 24
Thanks daisy!
Username: Lklives
Post Number: 3889
BELL EXPRESSVU..BEV
Last Update:
8/01/06
Aux 86 key
55 D1 31 F6 3B 79 91 E6
59 A5 20 98 77 FA FD CD
Aux 96 Key
6A 1B 0B EE 17 0C BC E5
0B 82 1B 07 B1 3A 26 B3
DISH NETWORK...DN
Last Update:
8/3/06
Idea Key 0:
DE E9 0B 22 87 B4 B6 33
C3 E4 3D 59 F9 22 7C 67 ACTIVE
Idea Key 1:
Why is there Black Channels?
Currently we are under an ECM by both providers that has caused FTA receivers to lose the ability to locate or process the command access code. This is not a key issue, so updating keys, reflashing a bin or rescanning is not the fix, but will get U local channels. The channels will remain black until a fix is written into the software. No cardless receivers have a fix for this issue except coo*lsat with card reader and few other receivers using card sharing.
Coo*lsat: KEY Line 10 and 11 are for Idea Key 0 and Line 20 and 21 are for Idea Key 1
Pansat: key 00 for Idea Key 0 and Key 01 for Idea key 1
Viewsat: line 08 and 09 for Idea Key 0 and lines 88 and 89 for Idea key 1
For Receivers with only two Key Lines, Enter Active Idea Key into 00 and 01
Username: Northman
Post Number: 163
Hey LK, which channels work with the BEV keys?
Username: Lklives
Post Number: 3892
BELL EXPRESSVU
Last Update:
8/02/06
Aux 86 key
Aux 96 Key
35 C7 FB 22 2F 47 16 ED
14 4F 2B 11 DA 9B 08 7E...Active
DISH NETWORK
Last Update:
8/03/06
Idea Key 0:
C3 E4 3D 59 F9 22 7C 67 (active)
Idea Key 1:
Currently we are under an ECM by both providers that has caused FTA receivers to lose the ability to locate or process the command access code. This is not a key issue, so updating keys, reflashing a bin or rescanning is not the fix, but will get U your locals. The channels will remain black until a fix is written into the software. No cardless receivers have a fix for this issue except coo*lsat with card reader and few other receivers using card sharing.
Coo*lsat: KEY Line 10 and 11 are for Idea Key 0 and Line 20 and 21 are for Idea Key 1.
Pansat: Key 00 for Idea Key 0 and Key 01 for Idea Key 1.
Viewsat: line 08 and 09 for Idea Key 0 and lines 88 and 89 for Idea key 1.
For Receivers with only two Key Lines, Enter Active Idea Key into 00 and 01.
