Mix subs
Username: Hockeyknight
Post Number: 155
hey i just bought 2 12" type r's from a frind but 1 is blown any1 know where i can get an old type r?????(300 rms)........... or could i put a new type r(500rms) in the same box with it?? thanks
Username: Poremski1628
Post Number: 41
http://www.cbrstereo.com/index.asp?PageAction=VIEWPROD&ProdID=47
theres the old 2ohm one they have the 4ohm on there too wasn't sure which one you were looking for. it would definetely sound better with the same subs and you would be paying about the same price either way
