My power steering is leaking!!!
Username: Crayola0
Wisconsin
Post Number: 321
I dont know what part is leaking but does anyone know how much it would be to replace everything? i think it is just a hose i hope.
Username: I_likes_da_bass
Bentonville, AR USA
Post Number: 73
http://autozone.com/servlet/UiBroker?UseCase=C001&UserAction=performSearch&Param eters=Auto+Store%7C%7EREGULAR+PARTS+LOOK+UP%7C%7EPower+Steering+Pump
Power Steering Pump for a
1999 Dodge Truck Durango 2WD
ATSCO Core Price
WITH RESERVOIR 7108 LLT $22.20 $61.99
ATSCO Core Price
WITHOUT RESERVOIR 7272 LLT $14.60 $36.99
POWERCRAFT PRESSURE HOSE $23.99
POWERCRAFT RETURN HOSE $23.99
I didn't know what engine your vehicle has or if it was 2 or 4 wheel drive, but the price should be fairly close to that regardless. I hope this helps.
Bentonville, AR USA
Post Number: 74
Also, I had to look it up under my zip code so the prices may vary slightly.
