Silver Member Username: AstrosafariDelhi, Ontario Canada Post Number: 532 Registered: Aug-05 | are the amps any good? im planning on getting another 15" clarion when i start makin money again, and i found some power ecoustics amps that arent all that expensive... http://www.cardomain.com/item/POWPS21200 2 of these, 1 per sub and i bet the prices are US. so ill be pullin some cash... |
Gold Member Username: RovinTrinidad & T... Post Number: 8698 Registered: Jul-05 | my bro has some PA amps 6yrs now daily in his car so i would say those he got back then r quite durable but they r overrated amps i have a PA 2100D 2100wrms @ 1ohm amp powering my 2 12s type Rs & these subs handle whatever wrms this amp puts out ...... |
Silver Member Username: AstrosafariDelhi, Ontario Canada Post Number: 534 Registered: Aug-05 | so then i wouldnt really be getting 500 watts at 4 ohms? |
Bronze Member Username: Naledge503Portland, Oregon U.S. Post Number: 73 Registered: Jun-06 | I have a PA A3000DB on 2 12 cvx's doing 1800 @ 2 ohms and it sounds pretty good. It is overrated but i dont know by how much. I do know is that it is very loud and the SQ is not that bad either. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1550 Registered: Dec-05 | if you're buying a PA just look this models: a1800db a2400db a3000db |
