Tyler Durden
Username: Hockeys_back
Post Number: 27
Tyler Durden i have a Multistar pantec2500, and for the bin i think its 277t.
Username: The_wank_artist
Post Number: 1406
Ok.
There is an auto roll option in the 227t bin.
Make sure it's off. You'll find it in the screen after entering the secondary pin.
Then add the codes.
Put both lines in the appropriate spots (00 and 01).
You should be good then.
From the sounds of your problem, the auto roll is on.
I've got a wicked hangover this morning, you?
Post Number: 28
hangover, dude i'm still drunk, haven't stoped drinking yet, i keep posting problems.....lol
anywho.....i have the autoroll turned off, and still nothing
Post Number: 1407
And you're entering the codes correctly.
Flip the switch at the back and back on.
Username: Min
Post Number: 217
make sure u are on those channels 7000 and up,or those channnles starting with letter K.because all the other channels are saying waiting for picture or black screen......
Post Number: 1408
Good point MIN.
Remember Hockey, these are only good for the locals right now. And for DN not BEV.
