Silver Member Username: JohnfiacIl USA Post Number: 322 Registered: Mar-06 | http://www.alpine-usa.com/en/products/product.php?model=SWX-1242D Just to make sure before i check all my space available to build the custom box to fit this and still have room for my batterys and amps and all..... 4 of these ran at 2ohms would be at 6000wrms right? are these subs underrated also? i am going to have 2 amps strapped togethor to, they claim 6000wrms at 2ohm but are also underrated.. 6000wrms at 2ohm? |
Gold Member Username: RovinTrinidad & T... Post Number: 8674 Registered: Jul-05 | never used those X but i would say do NOT give them 1500wrms each ! they r SQ subs so i would be afraid 2 power them 1.5 times like other brands like treo/dd ........ |
Gold Member Username: Alias747MN Post Number: 1150 Registered: Apr-05 | I don't think that you will have too much of a problem, just keep the sub output on the head unit set a little lower. A shop near me hooked a Kicker 2500.1 to a 12" Type X and it took it fine. And that kicker is rated at 2900+ wrms! |
