Optima, Kinetic, or Stinger?
Username: Alexv305
Tavernier, FL USA
Post Number: 297
What battery am I going to need for a 300a alternator and about 5000w RMS? Optimas seem cheaper but I can go a little higher if the Kinetic or Stinger is going to suit me better. It is going to be my main start up battery and the only battery.. If I need to batterys can I wire them up together if they are different?
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 1433
ive herd tht kinetics are very good batteries..but this is conterversial....kinetics last longer then optimas up to 5 yrs longer....ppl have had kinetics for up to 10yrs!!!
and if im not mistaken either kinetics is made by stinger or stinger is made by kinetics...im not sure i could be worng
but id go for the nietics.....
and ur sayin if one battery is diff under the hood could u wire a diff kinda battery in the back of ur car????
yes is the answer if tht^^^is wut ur askin
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 3059
if you are looking at stinger batts, just get a hawker...they are the same batt but w/o the stinger stickers. (hawker = stinger)
kinetics are good, but expensive as h3ll.
