Oh the contemplation
Username: Bobok7787
Post Number: 33
sorry guys if this seems like a repetetive question but....
ive been researching for awhile now and have come down to these....
-Crystal Compx
-Diamond Audio D9
-IDMAX
-Stereo In. Mag
-Treo SSi
-DD 3500d
and im still open for suggestions
What would you choose? list in order from best to worst if ya dont mind, and like i said, if theres any other noteworthy subs please let me know. Thanks for any input.
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1315
are we going for SPL, sql, sq?
what size are you looking to get?
what amp/amps do you have?
alternator?
ported or sealed?
Username: Drsmith
Montana USA
Post Number: 108
Audioque HD3
Username: Bobok7787
Post Number: 34
lets see... im more of a SQ guy, 12", i have a MTX 801D(800RMS@2OHMS), i think im gonna end up getting another one for each VC, this would also mean a new HO alternator, and last but not least probably vented. thanks for the input though
Username: Rovin
Trinidad & T...
Post Number: 8675
1 or 2 subs ???
since u say SQ u should also add JL 12w6v2 to ur list ...
Username: Bobok7787
Post Number: 35
just one, and thanks for the adition, now another question... since im planning on running two amps to one sub, and even thought they are matching amps, the wattages from each are gonna be different, does this affect the sub if each VC is getting a little different wattage? thanks ahead
Username: Extrmndor3
Chicago, Ill Us
Post Number: 1422
if ur going for sq go with diamond or id max plus ull get lil more db's for your dollar
i was runnin two amps to my single 18 inch sx i just match the gains and crossovers
Username: Showrides
Hartford, CT USA
Post Number: 119
How much you looking to spend on the sub? I have 2 mag 12's sealed with 450rms each, and they sound great. 1 12 would be more than enough for a very nice SQ setup. Also, a few hundred watts would get it plenty loud. You really don't need to throw 1000rms at a sub in a SQ setup, especially if you are dealing with a very efficient driver.
Username: Bobok7787
Post Number: 37
Arent ID MAX's sorta hard to come by these days? I also heard they were coming out with V4 by the end of this summer, i could be wrong...
Username: Econoline1
Vancity, Bc Canada eh
Post Number: 64
1000/1 + 13w7 @.75 Ohms ;-]
Username: Bobok7787
Post Number: 39
lets see thats a grand right there...with that combo and the rest of my equipment my system would be worth about 3 times more than my car, nice
