New member Username: PattygPost Number: 5 Registered: Jul-06 | I've looked all over and can't find a .5 ohm stable amp at 800-1000 watt RMS. Also what is anybodies opinion on a Powerbass Xtreme 3XL-12D http://www.powerbassusa.com/products/subwoofers/3xl_subwoofers.html |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 3058 Registered: Mar-04 | it will be easier to find amp that will do ~1000w at 2ohms. ex- kicker 1000.1 jbl bp1200.1 ed nine.1 |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 2677 Registered: Oct-05 | wut is the VC config?? DVC 1 ohm? |
Silver Member Username: Van_manBoston South, MA Post Number: 778 Registered: Mar-06 | US Amps USA-100HC its 400X2 at .5 ohms Best part, its MSRP is $1,839.00.it will also do 800 X 1 at 4 ohms bridged |
New member Username: PattygPost Number: 6 Registered: Jul-06 | yes vc config is DVC 1 Ohm Also how do I wire it for 2 ohm? |
Gold Member Username: RovinTrinidad & T... Post Number: 8641 Registered: Jul-05 | need a 1/2 ohm stable amp !? - checks MMATS @ www.woofersetc.com ....... |
Silver Member Username: Van_manBoston South, MA Post Number: 779 Registered: Mar-06 | MMats does 1600 or 2500 at .5 Too much wrms. Pat needs 800-900 |
Gold Member Username: RovinTrinidad & T... Post Number: 8642 Registered: Jul-05 | ya i was just showing some 1/2ohm stable amps but i do agree with marshall - it will sooooo much easier 2 get a 2ohms stable amp...... |
Silver Member Username: Van_manBoston South, MA Post Number: 780 Registered: Mar-06 | like these? PG Octane R8.01:1 800x1@2 Arc Kar900.1D 900X1@2 |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 2681 Registered: Oct-05 | how ur boat comin along marc? |
Gold Member Username: CtmikeCt. Post Number: 1142 Registered: Feb-06 | just so you know, that pg is rated 800w max, it's 600wrms. |
Silver Member Username: KillswitchjdPost Number: 271 Registered: Apr-06 | wire it in series, then it will be a two ohm load. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1385 Registered: Dec-05 | yeah, you'll find 2 ohm stable amps cheaper than 0.5 stable |
Bronze Member Username: 04redmach1Columbus, GA USA Post Number: 39 Registered: Mar-06 | Massive Audio P1500 is 920 rms @ 2 ohms. Check that amp out.. http://www.low-hz.com/commerce/catalog/product_info.php?cPath=22_31&products_id= 54&osCsid=a241705375916c5c74c05a0c16a844fd Those amps are lil cheaper than price showed too. |
