Username: Adam_s Post Number: 51 Registered: Aug-04
Wednesday, August 02, 2006 - 15:40 GMT OK I havent quite decided on subs. I am either going to get re se 12 or aa arsenal 12 is either one going to perform a lot better with 800 watts RMS than the other or will they both be a good choice??
Username: Bestmankind Los Angeles,
CA
Post Number: 4544 Registered: Oct-05
Wednesday, August 02, 2006 - 16:19 GMT are you getting 2 subs or 1? 800wrms is kinda overpowering those subs if you are only getting one.
Username: Adam_s Post Number: 52 Registered: Aug-04
Wednesday, August 02, 2006 - 16:28 GMT I am going to be getting one. The arsenal is rated for 750 and the se is rated for 600 and i thought they can handle over their rms?
Username: Jakeyplaysbass St. Louis,
MO
Post Number: 1332 Registered: Jul-05
Wednesday, August 02, 2006 - 16:44 GMT i would take an arsenal over a se. especially if your buying the RE with there new prices.
CA
Post Number: 4545 Registered: Oct-05
Wednesday, August 02, 2006 - 16:47 GMT oh my bad. i was thinking of the assasins. lol. i am with jake.
Username: Adam_s Post Number: 53 Registered: Aug-04
Wednesday, August 02, 2006 - 17:03 GMT alright thats what I was leaning towarrds anyway...thank you
