Sub truck
Username: Icecreamman5687
Post Number: 17
just wonderin would it be possible to fit 2 type r's under the back seat of a 2001 ford f150..
Username: Halter
Paulding, Ohio
Post Number: 156
A guy heard my system and came up and wonderd how he could fit 2 L7s in a back of 1 of those..I Was like .. yikes... and I dont think theres a way underneath the seat!
Username: Texas_bass
Houston, TX
Post Number: 388
the only way that i know of is to put spacers under the seat and raise it up a few inches one of mt freind did it to his truck
Username: Alpineduder
So u can jack up my sy..., Hell no C-a-n-a-d-a
Post Number: 51
with the raised seat does it still sound good and loud thomas????
Houston, TX
Post Number: 392
It sounded good but he had them facing up it would be better to face them foward with grills than to fire them into the seat of if you can manage faceing down the seat its self kinda kills it cause of tha padding
