Bronze Member Username: Trich23Gaylord, MI USA Post Number: 11 Registered: May-06 | I Need A Amp That Can Put Out 1500 RMS X 1 At 2 Ohms.. The Amp Will Be For 2 12 Inch CVX That Are Max 750 RMS Each.. |
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 515 Registered: Feb-06 | do you have a high output alt.? |
Bronze Member Username: Trich23Gaylord, MI USA Post Number: 12 Registered: May-06 | No But I I Will Be Getting One.. |
Gold Member Username: CtmikeCt. Post Number: 1134 Registered: Feb-06 | budget? you could stay kicker and get a 1500.1. |
Bronze Member Username: Trich23Gaylord, MI USA Post Number: 13 Registered: May-06 | well i want something not over 500 bucks |
Gold Member Username: CtmikeCt. Post Number: 1135 Registered: Feb-06 | a little over but not much, and worth it: http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17085 |
Bronze Member Username: Trich23Gaylord, MI USA Post Number: 14 Registered: May-06 | That Is A Great Deal |
