What size Capacitor
Username: Ckelley
Post Number: 12
I have 2 12"w3's and a 500/1 amp. I am looking am looking into getting a capacitor but am confused by their rating???
What size would be good for my setup??
thanks
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 8215
http://wickedcases.com/caraudio/capacitors.html
Username: Makmillion
United States
Post Number: 106
1.0 Farad is the matched cap for up to 1000 watts, .5 is for up to 500 watts.
Your amp is probably pushing more than 500 being as it's a JL, so get a 1.0 to be safe and don't skimp on a cheap Pyle branded cap, get a good name you can trust.
One thing, though.. with only 500 watts you aren't likely to need a cap.
But, if you choose to purchase one.. get a FARAD cap and not a CARBON cap.
Good luck!
