Box Making Question!
Username: Rangetop
Post Number: 7
Is it practical to use a reciprocating saw(sawzall) to make subwoofer cutouts for an enlosure? Or will the cut be too rough, uneven, or impossible to make a neat circle?
Username: Rovin
Trinidad & T...
Post Number: 8635
ur box will come out more crooked than some politicians ...
buya $30 powersaw & do it right .....
Username: Rangetop
Post Number: 9
i have a table saw for the straight cuts, i meant to use the sawzall for the subwoofer cutouts...but i think u might be right anyways...any other opinions?
Username: Rovin
Trinidad & T...
Post Number: 8639
oh ok - i though u meant 4 str8 cuts
ya u could use that - might be kinda cumbersome 2 hold it tho
a jigsaw is about $30 too or if u own a router buy a bit & circle cutting attachment .....
Greensburgh, PA US
Post Number: 99
Just be sure to keep the base secure against the surface when using that sawzall. My Skil sawzall gets pretty jumpy if I hold it above it's work surface, sure to bend blades. I'm a carpenter with alot of tools, and have been bit by every one of them. Safety first!
Username: Rangetop
Post Number: 10
Thanks for all the advice, but i think im just gonna suck it up and buy a jigsaw. I can't count the times that i've needed one anyways.
