Jl audio system
Username: 94chevyboy
Tampa, Fl
Post Number: 7
I recently had a system with 2 L5 15 on a 3000 watt power acoustik amp with a custom box in a 94 chevy caprice it got stolen now im think about going with 4 jl 12w3 with two 500/1 or 1000/l which would be better the main question is will this system sound better than my old one and hit harder and i was also thiking about porting the 4 12 with a custom box should i do that or leave it sealed. My second option is 4 15L7 with two hifonics new 2000 watt amp need info.
Username: Alias747
MN
Post Number: 1142
Haha, it will sound a hell of a lot better that's for damn sure!
Username: Blkwardog
Adel, Iowa Usa
Post Number: 63
jl's r made more for sq while kickers r made almost straight spl so i think it would depend on wut u listen to or think is more important...but for me id say the jl setup would b my choice
Username: Themax99se
Post Number: 43
(2) L5 15" on a power acoustik "3000 watt" amp
VS
(4) JL 12w3 with 500/1 JL amps?
OR
(4) L7 15" with Hifonics amps?
I think its ovious that the new setups are going to be "better". Definatly louder.
Username: Adddisorder
West palm, Florida
Post Number: 484
definatly go with jl
