2 12w3 vs 2 type-r 12
Username: Tiggerboi87
Pensacola, FL United States
Post Number: 112
Right now i have two type-r 12 being powered by two alpine mrd-605 amps. I am thinking of switching to two 12w3. Both of them should be able to run off of one of my amps. I just want to know which would most of yall choose between these and which ones would get the loudest,deepest, and which set would just plain sound better.
Post Number: 114
Comin people i need info
Username: Andysd03
Post Number: 317
keep the R man the r's are way louder what matter not enjoying the bass the 2 12" r are givin out? Jl isnt gona be much better unless u want quality in which case the type R would have better quality then the w3 if u got them tuned high and not satisfied tune them lower to 30-28HZ if u got them tuned low and not satisfied tune them higher 35 to 40HZ the higher tuning means more bass!
Post Number: 115
Haha yea i just want more spl with while still using the same amps i have now.
Username: Andysd03
Post Number: 322
more bass fine then tune type R to 40HZ ud def notice a difference
Post Number: 116
Theres a problem. I dont know how to do this. I do have a ported box. But i dont know how you tune them. I thought u had to do it when you make it.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 8231
rule number 1..on the fourm never listen to andy...lol
the spl...change will not be noticable...but the sq the jl's will produce will be...
Post Number: 117
haha i c. Well i was also thinking of goin up to the 12w6's. Those will do something i hear(ive never heard them personaly)
Username: Andysd03
Post Number: 323
those type R would def be louder then the W6 chauncey hates alpine so of course hes gona put them down the drain!if u want spl keep the R if u want SQ i guess the W6 but it wont be nearly as loud as your R's if u port them correctly
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 1389
I would go for the JL W6 becuz thier sound quality is amazing and also the are very well built i no ppl who still have JLs from the 90s that work amazing...GO for the JL
i think of the type R as a beginner sub....
