Kicker cvx vs cvr
Username: Grendelendel
Post Number: 10
is there a huge difference btwn the two? im contemplating if i should get 4 12in 2ohm cvrs or 2 2ohm 12in cvx's. each setup would push around 1500watts rms. but if theres a huge sound difference then i might go with the cvx's.
if this helps i have a fairly big trunk 1996 jeep grand cherokee and i barely use the trunk so i can make a box to fill up the trunk but has to stop below the rear window height wise.
whats your guys input on this?
also are there better subs out there i should look into for the same price range?
Username: Allstar13
i think u should get the cvxs they r pretty much a round L7, they dont hit quite as hard but have a little better sq the diffrence isnt really much.CVRs r pretty good though my friend has some but my cvxs sound alot better and hit alot harder and we have the same amp
Username: Loudon
Post Number: 426
guys this kinda thread has been done 8000 times ... do a search before u make a thread ... it gets annoying ...
cvx>cvr - end it there
