New member Username: Tank6585Post Number: 2 Registered: Jul-06 | Anyone have a price on one of these beasts let alone even hear one? |
Silver Member Username: Atllefty12Pinellas, Fla. Post Number: 110 Registered: Jul-06 | $1625 for the 15" |
Silver Member Username: Dsmith07Post Number: 111 Registered: Jun-06 | how many watts can they handle? |
Gold Member Username: CtmikeCt. Post Number: 1100 Registered: Feb-06 | $1,295 for the 12" |
Gold Member Username: CtmikeCt. Post Number: 1101 Registered: Feb-06 | re says 1600, but i was told by a dealer to give it 2000 daily and i'd be happy. |
New member Username: Tank6585Post Number: 3 Registered: Jul-06 | Damn thats just crazy, but from vids i saw they seem to beat the W7s excursion. |
Silver Member Username: Atllefty12Pinellas, Fla. Post Number: 111 Registered: Jul-06 | its 2000 rms for the 06 model |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4423 Registered: Oct-05 | "Damn thats just crazy, but from vids i saw they seem to beat the W7s excursion." man at that price they better beat the W7 in more than just excursion. lol |
Gold Member Username: CtmikeCt. Post Number: 1102 Registered: Feb-06 | depends on where you live i guess cause i can get a 12" xxx at the same price as a 12w7 (both $800 brand new) |
New member Username: Tank6585Post Number: 4 Registered: Jul-06 | For 800 i would consider buying it, but 1300+ forget it. |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4054 Registered: Aug-05 | check ebay. they are WAYYYYYY cheaper. |
Gold Member Username: CtmikeCt. Post Number: 1103 Registered: Feb-06 | only i found on ebay: http://cgi.ebay.com/RE-Audio-XXX-12-subwoofer-BNIB-dual-2ohm-06-model_W0QQitemZ1 30009635405QQihZ003QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
