New member Username: Jynxsk8Post Number: 3 Registered: Jul-06 | i have a logitech x530 surround sound system (5.1 PC surround sound) and im using the console adapter will that decode it to pro logic 2x? http://www.logitech.com/index.cfm/products/details/US/EN,CRID=2177,CONTENTID=906 7 |
Gold Member Username: Project6Post Number: 8574 Registered: Dec-03 | No...you will only get matrixed surround, but no pro-logic. |
New member Username: Jynxsk8Post Number: 6 Registered: Jul-06 | waz matrixed? |
Gold Member Username: Project6Post Number: 8646 Registered: Dec-03 | That is when the signals are split into the rear to simulate a surround set-up. |
Bronze Member Username: Jynxsk8Post Number: 12 Registered: Jul-06 | what do i chose Mono, Stereo, Dolby Pro Logic 2 or Dolby Digital Pro Logic 2 |
Gold Member Username: Project6Post Number: 9005 Registered: Dec-03 | Depends on what you like. |
Bronze Member Username: Jynxsk8Post Number: 13 Registered: Jul-06 | no i mean to set up the matrix or watever ya call it |
Gold Member Username: Project6Post Number: 9109 Registered: Dec-03 | Pro-logic |
