LG LRH 790 How to remove record blocking signal?
Username: Slavik
Hi,
I have a LG RH790(DVD recorder with HDD).
I want to record to my HDD from a digital receiver but for some movies I get a message saying that 'record blocking signals detected'. Does anyone know how I can remove this?
Username: Project6
Post Number: 9043
It's not cheap and not guaranteed to work for all copy protection.
Username: Samijubal
Post Number: 2893
You can try a stabilizer which may or may not work, around $50-100, or you can buy a time base corrector for around $200-$1000. You can get Sima stabilizers at Best Buy or Circuit City, then if it doesn't work you can return it. You can probably get a Sima for about half the price of BB or CC on ebay, but if it doesn't work, you're probably stuck with it.
Username: Project6
Post Number: 9054
Much more trouble than they are worth for movies that will go in the bargain bin anyway. Just get the original movies, less trouble, better quality.
