What Is The Difference ???/
Username: Trich23
Gaylord, MI USA
Hey What Is The Difference Between The Comp CVX 2 Ohms And 4 Ohms DVC....
Username: Basshead86
Google is your Friend, FL
Post Number: 4024
one has 2 2ohm voice coils.
and one has 2 4 hom voice coils.
the first one can be wired to 1 or 4 ohms
and the second can be wired to 2 or 8 ohms
Username: Trich23
Gaylord, MI USA
Post Number: 7
So What One Is Better Because I Ordered The 4 Ohms One And They Are Sending Me The 2... What Amp What You Use For The 2
Post Number: 4027
so you are getting 2 Dual 4 ohms CVX's....
you need an amp that puts out roughly 1500watts at 1 ohm.:-)
i forget their RMS rating.....
Post Number: 4028
how about a kicker amp? go to their site and find one.
Username: Stnorris
Eldridge, IA US
Post Number: 891
ya it sucks though for him, cause he got the dual 4. most of the kicker amps are at 2 ohms. he could have got the zx1500.1.
lol how did u order 2 cvxs, without knowing about dual 2 ohm and dual 4 ohm?
Username: Naledge503
Portland, Oregon U.S.
Post Number: 55
thats right muddy. 750 rms each, assuming you got 12's. but i think he's sayin he ordered the 4 ohm and they are sending him the 2 ohm. anyway to answer your question they are the same. the difference is in the way you wire them. I just got some cvx 2 ohms and am deeply regretting that decision. I so wish i would have got the 4 ohms. It is way easier to find an amp to run the rms needed at 1 ohm than at 2 ohm, well at least in my price range. I let some punkass audio store owner convince me that it is so terrible to run at 1 ohm. this was before i found this forum.
Username: Cenus
420 , 420 420
Post Number: 2045
if your getting the dvc2ohm subs get a zx1500.1 amp if your getting the dvc4ohm subs get a kx1200.1 or sx1250.1.
Username: Trich23
Gaylord, MI USA
Post Number: 8
No See I'm Getting The 2 Ohms Ones Because He Sent The Wrong Ones.. I Want A Amp Cheaper Then 300 Bucks That Can Power These... Name Out Some Models Please
Post Number: 56
What size are they? If 12's, look into the audiobahn A16000V. its under $300 on e-bay. That would probably be your best bet. If there is anyone else with suggestions, I would like to hear, as I am in the same boat as he is.
Username: Cenus
420 , 420 420
Post Number: 2047
mtx 1501d 1300-1400wrms, they go around $300 on ebay.
