New member Username: GeigerrPost Number: 3 Registered: Jul-06 | I just got 2 12inch cerwin vega stroker. 2000watt RMS, but when buying them i didnt realized that one was model number 122 and the other was 124, will it matter if one is DVC 4 ohm and the other is DVC 2 ohms and i plan on bridging them into series into a mono cerwin vega EXL1200D amp, stable @ 1 ohm. So will it matter and how much? Has anyone heard these strokers yet, it was very difficult to find these. I had to buy them on ebay. |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1581 Registered: Aug-05 | They're an SPL sub to start. The 1200D will put out only 1200W RMS, so 600W RMS to each, not NEARLY enough. But if you're able to run the subs together in parallel-series, to create a 1 ohm load at the amp, there shouldn't be a problem... |
Gold Member Username: RovinTrinidad & T... Post Number: 8582 Registered: Jul-05 | https://www.ecoustics.com/electronics/forum/car-audio/250534.html |
New member Username: GeigerrPost Number: 8 Registered: Jul-06 | Yeah, i called cerwin vega and they said that if i ran them bridged into one, then i will get over 130db @ max. I dont think i really need any more then that. |
