New member Username: IrapeopleNew York, NY Post Number: 1 Registered: Jul-06 | Suddenly i can't load tunes into my nano. Used to work fine. hey are m4p's from music store. Itunes is version 6.0.5. HELP! |
Silver Member Username: FtalifePost Number: 144 Registered: Jul-06 | Try to reboot it. http://www.apple.com/support/ |
Silver Member Username: FtalifePost Number: 145 Registered: Jul-06 | if you can't figure it out find your local ipod store. |
Silver Member Username: FtalifePost Number: 146 Registered: Jul-06 | The apple store I mean. They will fix it for you or replace it if you are under warranty. |
Silver Member Username: FtalifePost Number: 147 Registered: Jul-06 | If your warranty is almost up it is usually a good deal to buy the extended warranty. If the price is right. |
