Help what happens when you turn the volume of your 150watts * 5 amp to 3.speaker is 135watts
It depends. What is the max # on your amp. If it something like 20 and your turning it up to 3, your speakers will live because they are only getting a fraction of that 150 watts. BUT- If the max number is... 5, for example, then your speakers are toast. Kepp the volume down, because your pushing those speakers hard with power that they arent designed to handle. They will blow.
