Philips GoGear Compatable?
Username: Beforeiforget87
Towanda, PA USA
I Have a Sony Xplod Head Unit
Link:http://walmart.scosche-cars.com/products/?search_constraint=1&search_query=Sony& sfID1=24&productID=1585&walmartProductID=4541650
wtf do i need for the aux to hook up my gogear?
does it connect from the aux to the headphone jack???
Towanda, PA USA
also, where can i find cord and what is it calld, if it's possible
Username: Illuminator
Post Number: 3472
It should. Just buy an RCA to headphone jack cord.
Username: Dkchillin
Vermont
Post Number: 201
Looks like your deck has a front 3.5mm AUX in port, so you'd want a dual 3.5mm cable, something like this. If it had an rca AUX in, usually in the rear of the deck, then you'd need what Jexx suggested which looks like this.
