Wow
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 435
me and my 15" H2 without an amp went to my local car audio shop to get metered....and while playing top back by T.I. i measured at 127.6....i was suprised it got that loud without an amp.
Username: Blainew
Post Number: 1412
what do you mean without an amp???
Username: Tdbdadrummer
Wellsburg, WV USA
Post Number: 1556
I bet he has the sub wired up directely to his HU.
Not a great idea, since HU's aren't meant to handle lots of impedance load.
Username: Troy81
Tavernier, Fl Us
Post Number: 719
what? haha, HU power or suttin?
Post Number: 437
there wasnt an amp hooked up to it...it was just running off my HU
Username: Troy81
Tavernier, Fl Us
Post Number: 720
thats not good, fix that
Post Number: 438
i am as soon as my amp comes in the mail.....
Username: Blainew
Post Number: 1413
why is it bad to have a sub hooked to a head unit..... as long as your running it @ 4 ohms, arent ya good?
Username: Troy81
Tavernier, Fl Us
Post Number: 725
idk, sub ohms and speaker ohms seem different to me, like even though its the same ohms its still harder to push, but im sure it really doesnt matter but i would still fix it asap
Username: Carguy
Post Number: 5588
If you hook up a sub to HU directly, then you're not really measuring music, but noise/distortion.
The output power on HUs are very low and limited. Therefore if you push it too hard, it will clip/distort. A sure way of blowing your HU and the sub.
Username: Troy81
Tavernier, Fl Us
Post Number: 728
and now that i think about it your also trying to play music through your sub which isnt good, and yes if you work you HU to hard it will clip which is bad for the HU and the speaker
Username: Genocyde21
Post Number: 63
ok i don't get this. How the hell can your h-u power ur sub. How much is it sending it, like 20wrms????
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2548
no, more like 12wrms actually, lol. its enough to move the sub, but it'll sound like crap.
and an ohm is an ohm, but with speakers its always varrying depding on frequency.
Stockbridge, GA USA
Post Number: 2549
i left some letters out, lol.
*depending
Username: Usask8er1
Appleton, Wisconsin USA
Post Number: 365
Cant alot of the spl still be measured off his 6x9s or other components? no way that sub can push much with only 12wrms. i give mine around 2300-2500rms then again it hits alot higher than that.
Username: Astrosafari
Delhi, Ontario Canada
Post Number: 479
i had my 15 runnin straight off the hu for a long time, only thing that ever died was the battery. it sounded real good, and the words of the music were much liuder, its better with the amp though... i had it on my alpine HU, 45wx4 and i was also running 8 speakers too. 2 6.5's, 4 6x9's, and 2 4's.
Post Number: 454
all i have is 2 4" mb quart components...
