Bronze Member Username: HomercleezePost Number: 14 Registered: Mar-06 | ive looked at a few different places and seen different results. anyone with expierence know exactly how big one of these are? i have limited space to mount the amp next to my converter so i might have to go with a different amp for my treo. thanks in advance |
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 446 Registered: Feb-06 | you can almost mount an amp anywhere... |
Bronze Member Username: HomercleezePost Number: 15 Registered: Mar-06 | its not for a car dude, i have limited space to mount an amp. can anyone please give the correct dimensions? |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3987 Registered: Aug-05 | 11-5/16"W x 2-5/8"H x 13-1/4"D |
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 449 Registered: Feb-06 | wow mine are different..Dimensions: 1-7/8" H x 9-7/8" W x 11-7/8" D |
Bronze Member Username: HomercleezePost Number: 17 Registered: Mar-06 | THANK YOU, muddy. *sigh* the amp is too big, does anyone have a suggestion other than the brutus for a compact amp to power a treo tsx 10" dual 4 ohm? |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3989 Registered: Aug-05 | Height: 1.88 in Depth: 11.88 in Width: 9.88 in i can't find any that are the same either. lol your best bet would be to email A-bahn's tech dept. and they will tell you. these amps put out closer to 600wRMS, incase you were unaware. |
Bronze Member Username: HomercleezePost Number: 18 Registered: Mar-06 | "wow mine are different..Dimensions: 1-7/8" H x 9-7/8" W x 11-7/8" D" now that would fit. i cant go over 10 inches in one direction due to the height of my radio.......where did each of you get those figures from? |
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 453 Registered: Feb-06 | http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=106 |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 2617 Registered: Oct-05 | the a8000t's muddy?? they put out 810 watts |
Bronze Member Username: HomercleezePost Number: 19 Registered: Mar-06 | heres another thing thats gotten me confused, ive seen the a8000V and the a8000T out there. the "V" is the bigger one, is there a difference? or is the 8000T an older model or something? |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3991 Registered: Aug-05 | the a8000t is a class a/b amp. it has 2 30 amp fuses...which is closer to 600wRMS than it will EVER be to 810. lol but w/e i am not sure about the V i got one from bizrate and one form sonicelectronix |
Bronze Member Username: Naledge503Portland, Oregon U.S. Post Number: 47 Registered: Jun-06 | yeah the a8000t is last years and the a8000v is this years. |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 259 Registered: Jan-06 | What about the DUB4001 it says its a 800 watt class a/b mono amp..and less expensive than the a8000t. what is the difference? |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1558 Registered: Aug-05 | "these amps put out closer to 600wRMS, incase you were unaware.:-)" Isaac has tested that line of amplifiers...All put out the power listed. Of course, not being JL Audio /series, the voltage plays the important factor. |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3997 Registered: Aug-05 |
there in lies the problem....not everybody's charging system runs at 14.4V lol |
Gold Member Username: Killerzracing71Fredericksburg, Virginia United states Post Number: 1060 Registered: Aug-05 | chit i know mine doesnt.....13.7 is the highest iv seen an i looked yesterday.....its 11.8 off it was 13.2 before that battery is dead...... |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4012 Registered: Aug-05 | mine runs at like 15V |
Gold Member Username: JakeyplaysbassSt. Louis, MO Post Number: 1300 Registered: Jul-05 | 14.2 - 14.8v for me... and i have a crappy battery |
