Gold Member Username: Iufan4lifeulPost Number: 1122 Registered: May-05 | I have an 85 amp alternator, a duralast gold battery, a 1.2 farad cap. I also have a Crossfire 600D and a Kicker 250.2. The alternator is only putting out 13 amps at max right now so I have been calling around. 2 high end alternator shops here in Louisville will not touch the car unless to do a factory replacement. They said that a HO alternator or a rebuilt alternator will mess up something in the car. And because of time ( I need this to get fixed) I will be replacing it with another 85 amp alternator :/. So much for me wanting to get a High Output . |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4360 Registered: Oct-05 | why don't you contact nate or iraggi alternators. they will build you one that won't die crap out on you. they even give you warranty. most local alternator places don't know too much about ho alt. |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1383 Registered: Feb-06 | i just installed my new iraggi alternator, its a 180 amp alternator it cost me 184 includin shippin, it works fine but i still have a little dimmin im gonna add a new batterie, no bro the alternator will not harm your vehicle if they mnean its gonna take power from your engine yes but its not gonna harm your engine, it will take only 1hp |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4361 Registered: Oct-05 | yeah the iraggi alternator is the sh!t. i have a 260a ho alt and i love it. |
Gold Member Username: Iufan4lifeulPost Number: 1123 Registered: May-05 | Well, I need it tomorrow so I really don't have a choice. |
Gold Member Username: Killerzracing71Fredericksburg, Virginia United states Post Number: 1058 Registered: Aug-05 | LILrob where did u get ur alt irragi....dont they sell those on ebay...... cuz im lookin to get 1...... i found i might need 300 amps though |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3985 Registered: Aug-05 | http://stores.ebay.com/Iraggi-Alternator-and-Electronics |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1385 Registered: Feb-06 | ^^^^^^ wat muddy says, mine its a 180 amp and 120 at idle, it was 156 with shippin 184.6 it wuns good butlike i said before i still got some diimin |
Bronze Member Username: BenzinoMichigan US Post Number: 44 Registered: Jun-06 | killerzracing71 what you running? 300a is alot.. Lil rob you have the big three done? |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1388 Registered: Feb-06 | yup, i got two runs of 4g for power and ground from my alt and batterie |
Silver Member Username: TweekerPost Number: 293 Registered: May-06 | i thinkn those alts are to much from the link you posted muddy thye say thye are 240amps but like 150 at idle lol. or maybe is just my type of car thats why it costs a lil more |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 2624 Registered: Oct-05 | tweaker!! |
Silver Member Username: TweekerPost Number: 294 Registered: May-06 | what? |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4369 Registered: Oct-05 | tweaker!! |
Gold Member Username: JakeyplaysbassSt. Louis, MO Post Number: 1299 Registered: Jul-05 | it looks fun... tweaker!! |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4008 Registered: Aug-05 | |
Gold Member Username: Killerzracing71Fredericksburg, Virginia United states Post Number: 1073 Registered: Aug-05 | TWEAKER Ray i was gona run 1 Orion 2500d 2 Orion 400-2 so thats 300amps or so right there |
