Does this mean my Voice Coil is F-ed, or will the Sub still work????????
Username: Rickyhayer
the voice coil on the back of my 10" CVR kicker seems to be fucked... or so says a buddy of mine... i haven't hooked these subs up yet, nor have i heard them play...
anyway.. when i look at my sub from the side and push the sub up, the yellow voice coil goes up with it.. apparently its not supposed to do that (its supposed to be glued down) does this mean my subs wont work??
Username: Basshead86
Google is your Friend, FL
Post Number: 3954
i dunno about the CVR's but you can see many subs VC's when you push the cone up.
can you post pics......i am having a mental block trying to picture this. lol
Here is my sub with the cone down
http://img99.imageshack.us/img99/8569/sub1ky8.jpg
and here it is with the cone up and the VC coming up with it
http://img134.imageshack.us/img134/6981/sub2ln1.jpg
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 8113
i think im seeing double???
Post Number: 3958
HAHAHAHAHAHAHAHAHAHA
that is the spider.
it is supposed to move with the cone.:-)
silly n00b.
being a silly noob is better than having a shitty sub... thanks alot.. i'll be able to sleep better... :D
Post Number: 3959
good. glad i could help.
tell your friend to stay away from you for a while. ok? lol
Username: Troy81
Tavernier, Fl Us
Post Number: 695
does it plaY? if so obviously it will play haha, this was a rather weird thread, posted 2 of the exact same picture i think
Post Number: 7
if you look at the pics one after the other, you can tell that one has the cone pushed up... but yea, i hooked the sub up to a speaker amp today, just to see if the sub does anything, and it was fine.. the amp was shitty so the sub didnt make much noise, but it was performing as i thought it would...
Post Number: 3966
yo dude....read this link.:-)
http://www.bcae1.com/speaker.htm
Post Number: 10
great link... props on that one...
