Bronze Member Username: Vc23Post Number: 69 Registered: Mar-06 | Yeah no idea of how to do it just need a little explaining, i have no sub, but would like to know for future reference. |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4356 Registered: Oct-05 | here are some links that can help you calculate the port lengths. http://www.carstereo.com/help/Articles.cfm?id=31 http://www.the12volt.com/caraudio/boxcalcs.asp |
Gold Member Username: RovinTrinidad & T... Post Number: 8547 Registered: Jul-05 | if u r a newbie then i strongly suggest u use PVC ports since its easy 2 remove if u want 2 change tuning ... |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3975 Registered: Aug-05 | agreed.^^^^^ |
