Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 240 Registered: Jan-06 | Would it be possible to make a round box for subs. I was thinkink of something in the shape of a Y with one sub firing down into each of the upper parts of the Y and the bottom part being the mouth where the sound comes out. so a few questions 1>is it possible to make it? 2>what would it be best made out of? 3>how would you figure the square inches of each part? 4>what would it sound like? thanks for any answers. |
Bronze Member Username: Sofakingcool2007Post Number: 58 Registered: Jul-06 | I knowits possible.. my cerwin Vega subwoofer is housed in a cylinder enclosure.. I got it from my brother and it came in that enclosure |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 242 Registered: Jan-06 | OK, but thats a cylinder, I was wonering if its possible to make a box for 2 subs in the shape of a Y. A Cylinder is just a "bass tube" which I had when I had a Bazooka, and it didnt sound real great |
Silver Member Username: StnorrisEldridge, IA US Post Number: 715 Registered: Apr-06 | its possible to make. ive seen one like it before. the best would be to use fiberglass or seomthing like it. it probably wouldnt sound too bad... |
Gold Member Username: PelonaPerres, California Post Number: 1686 Registered: Dec-05 | yes its possible but can u build it? |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 244 Registered: Jan-06 | well, honestly, I doubt I can build it...maybe someone makes them |
Silver Member Username: Troy81Tavernier, Fl Us Post Number: 641 Registered: Mar-06 | ask wahl im him at sploosh56 |
Silver Member Username: Troy81Tavernier, Fl Us Post Number: 642 Registered: Mar-06 | ask wahl IM him at sploosh56 |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 248 Registered: Jan-06 | dont have IM yet, I get on computer at library. However, I am moving and my new apt has cable and high speed internet for free, so I will be hooking up my home computer then. |
Silver Member Username: Bulldogsm2008Iowa City, Iowa Post Number: 266 Registered: Mar-05 | you can go to the nearest menards lowes home depot etc.. and get a round tube used to pour concrete in idk what theyre called. and fiberglass the inside to get the cylinder shape... thats what i would do if i was to make a cylinder box |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 250 Registered: Jan-06 | How do you "fiberlass" something? |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 251 Registered: Jan-06 | How do you "fiberGlass" something? |
Silver Member Username: HomegrowncamWatauga, TX United States Post Number: 302 Registered: Jan-05 | theres bendable wood and you can fiberglass over that. |
Bronze Member Username: Poremski1628Post Number: 20 Registered: Jun-06 | http://www.topedgeonline.com/detail.aspx?ID=13813 check that out im not sure if thats what your looking for but i found that |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 252 Registered: Jan-06 | nope, I want a Y shaped tube for 2 10's |
