Silver Member Username: Talon_es93Post Number: 329 Registered: Mar-06 | whats the most u have ever heard 2 12" VRs hit ....i wanna know high i might be able to get mine to go... i can only do like 128 right now but i think it should be able to go high then that |
Gold Member Username: Cenus420 , 420 420 Post Number: 2004 Registered: Jan-05 | 128 with 2 cvr's LOL i was doing 127 with the comps and a 200watt amp, i know a friend who has 1 12ported and hes doing like mid 130's. |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 2469 Registered: Oct-05 | lol. wut are u usin?? i can get my 2 12"s to do 140's |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 2470 Registered: Oct-05 | i hate the comps... how do u like em' dustin?? haha, thats my name |
Silver Member Username: Talon_es93Post Number: 330 Registered: Mar-06 | sh!tty box prolly... wat box do u got to get em in 140s |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 2473 Registered: Oct-05 | a box. lol, port tuned to 38 |
Silver Member Username: Talon_es93Post Number: 331 Registered: Mar-06 | ain't gunna share man??? ![]() |
Silver Member Username: Talon_es93Post Number: 332 Registered: Mar-06 | http://www.subwoofertools.com/forum/ported-box.asp?Ew=40&Eh=15&Dia=6&Xmax=12.64& Vd=.18&NumW=2&Vb=5&Fb=33&Qts=&Vas=&Fs=&CE=1.5 would this get me in the 140s or any higher then we're i'm @ now? |
Silver Member Username: Talon_es93Post Number: 333 Registered: Mar-06 | http://www.subwoofertools.com/forum/ported-box.asp?Ew=40&Eh=15&Dia=6&Xmax=12.64& Vd=.18&NumW=2&Vb=5&Fb=33&Qts=&Vas=&Fs=&CE=1.5 would this get me in the 140s or any higher then we're i'm @ now? |
Silver Member Username: Talon_es93Post Number: 334 Registered: Mar-06 | http://www.subwoofertools.com/forum/ported-box.asp?Ew=16&Eh=26&Dia=6&Xmax=12.64& Vd=.18&NumW=2&Vb=5&Fb=33&Qts=&Vas=&Fs=&CE=1.5 or this so that way i can have the port goin from one end of the box to the other on the top or on the bottom |
Silver Member Username: Denali_on_22sMaryville, TN Us Post Number: 113 Registered: Feb-06 | Thats a really fucin deep box dude see if you can make it a lot wider, tune that b!tch to 40 hz or so if all your worried about is SPL |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 2489 Registered: Oct-05 | tune it to 40 is you want major spl man |
Silver Member Username: Denali_on_22sMaryville, TN Us Post Number: 114 Registered: Feb-06 | exactly... if all he is worried about is gainin decibels why wouldnt he? |
Gold Member Username: JakeyplaysbassSt. Louis, MO Post Number: 1269 Registered: Jul-05 | 4 compvr 12s and 2 crossfire 1000ds- 150.2 box is tuned to 38 in an old explorer. |
Silver Member Username: Talon_es93Post Number: 336 Registered: Mar-06 | the box is acually 16 tall 26 wide its just that that the only way i could do it so it can give me a box with the port wide as hell so it goes from one side the the other of the box... the green or yellow will be the bottom and both subs will be mounted on the redi'll try to draw it out so you guys can understand |
Silver Member Username: Talon_es93Post Number: 337 Registered: Mar-06 | http://www.subwoofertools.com/forum/ported-box.asp?Ew=16&Eh=26&Dia=6&Xmax=12.64& Vd=.18&NumW=2&Vb=5&Fb=40&Qts=&Vas=&Fs=&CE=1.5 guess it could be done like this too....hopfully bassman will be a friend and share...imma go to a compition on the 29th man so i need help... ik i ain't got much but the comp is in a small town so they shouldn't have much...i heard that the best system there is 4 12"s that hit in the 140s..so maybe i can get mine that high and then add my brother in laws CVRS to and maybe get in the 150s |
Silver Member Username: Talon_es93Post Number: 338 Registered: Mar-06 | ![]() |
Silver Member Username: Talon_es93Post Number: 339 Registered: Mar-06 | ![]() |
Silver Member Username: StnorrisEldridge, IA US Post Number: 674 Registered: Apr-06 | .d: none of those boxes would work at all...becuase a 12" cvr displacement is .07065. not .18...thats a pretty big difference..lol over twice the displacement.....so MAKE SURE You Change that before you build the box LOL. |
Silver Member Username: Talon_es93Post Number: 340 Registered: Mar-06 | just chage it to .07065 man it wont' hurt you... |
Silver Member Username: StnorrisEldridge, IA US Post Number: 697 Registered: Apr-06 | what the hell are you talking about. i guess i wont help you then next time. but i just saved you from building a messed up box |
Silver Member Username: Talon_es93Post Number: 341 Registered: Mar-06 | come on man u know i love you |
Gold Member Username: Cenus420 , 420 420 Post Number: 2006 Registered: Jan-05 | "i hate the comps... how do u like em' dustin" bassman- the comps were my first system, i got 2 12's and a kx200.2, the sq isn't too bad, the spl wasn't bad for only 100wrms each sub, but now there just sittin in my room, im thinking about making a HT setup with them. LOL |
Silver Member Username: Crayola0Wisconsin Post Number: 209 Registered: Jun-06 | What do u think this setup would hit? 2 12" CVR's each in there own box 2.25 cubes tuned to 35Hz powered by an audiobahn a8000t. |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1539 Registered: Aug-05 | I don't think that CVR's need 2.25 Cu. Ft...The Assassins only need 2 Cu. Ft., and they have a greater displacement. |
Gold Member Username: Cenus420 , 420 420 Post Number: 2008 Registered: Jan-05 | james- my friend is doing mid 130's with one cvr12 and 400wrms, and his box is tuned low than 35hz, so im guessing that with a well made box and a good electrical system you could do in the low 140's. but it also depends on what kind of car you have. |
