Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1531 Registered: Aug-05 | Got rid of Verizon DSL, and got Comcast Cable Internet... But that's not the best part...I got my ported enclosure built, and put in, as well as I installed my A6004T (that was fun...). I posted a video of it on myspace, and I'll post the link to it ASAP. It was done at night, with Ridin' by Chamillionaire, so it's A. Not ALL THAT powerful sounding (until the end), and B. Hard to see...But it gets the point across... Let's just say while going down Main Street in my town it's easy to set off 2-3 car alarms hehehe... |
Gold Member Username: Matt12490Benicia, California USA Post Number: 1136 Registered: May-05 | damn i was wondering what happened to you. That would be with 2 assassins if i remember correctly? |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1532 Registered: Aug-05 | Yea...I'm waiting for MySpace to finish processing it, and I'll put it up... |
Gold Member Username: Matt12490Benicia, California USA Post Number: 1137 Registered: May-05 | why dont you go film another video now in the day time? |
Silver Member Username: Crayola0Wisconsin Post Number: 195 Registered: Jun-06 | what size assasins? |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1533 Registered: Aug-05 | http://vids.myspace.com/index.cfm?fuseaction=vids.individual&n=2&videoID=9448805 99 There's the video...I borrowed the Digital Camcorder from a friend of mine...Oh yea, you'll hear me be "enthusiastic" about the car remote...The reason the mids and treble drop is because an ambulance go up the street at that time and I put the HU in attention mode...but the bass is still heavy at that time... I no longer have the camcorder... |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1534 Registered: Aug-05 | 12" Assassins... About my ported box...You all know that the slot port generally makes an "L" shape inside the enclosure...Well, when I put the box together, I forgot to put the longer portion of the "L" in (the part that makes the inside walls of the port. Instead I ended up using the short part of the "L" shape as the entire port...I don't know what it's tuned to...But it has the depth of a sealed enclosure (sound), but the SPL of a ported enclosure. Not sure on the type of enclosure you'd classify it as, but it sounds really good... |
Silver Member Username: Crayola0Wisconsin Post Number: 197 Registered: Jun-06 | What do u think would have better spl 2 12" assasins or 2 12" CVR's |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1535 Registered: Aug-05 | Good question...My friend has 2 ported CVR 12's, and his have limited excursion compared to mine (they're really bad sounding on songs with the inverted excursion). My system is louder with better SQ. But I've wondered if maybe his box is too small even though the install shop around here built it for CVR's... But from what I've seen the Assassins can stomp on CVR's especially on the lowest of frequencies... |
Silver Member Username: Crayola0Wisconsin Post Number: 199 Registered: Jun-06 | cause im looking for a cheap setup. and im thinkin about gettin a audiobahn an audiobahn 8000t or 8000v and i was gunna get two 12" cvr's. but the assasins are about the same price so idk. any other opinions. And how do u like your 8000t? And what voice coil config. does it have? |
Silver Member Username: Crayola0Wisconsin Post Number: 200 Registered: Jun-06 | And u say u can set off car alarms? |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1536 Registered: Aug-05 | I have...Often when playing Patron by Yung Joc. It depends on how you end up building your enclosure too...But the lows they produce are for lack of a better word "sick". Especially for the price and being 12's. AA seems to have an all around good batch of woofers out at this time... |
Silver Member Username: Crayola0Wisconsin Post Number: 203 Registered: Jun-06 | what is the voic coil config. on those subs? |
Gold Member Username: Matt12490Benicia, California USA Post Number: 1142 Registered: May-05 | tyler- whats the port length on that box? you know? and the volume of the box |
Silver Member Username: AdddisorderWest palm, Florida Post Number: 441 Registered: Jan-06 | single 4ohm |
Silver Member Username: AdddisorderWest palm, Florida Post Number: 442 Registered: Jan-06 | oh and your vid isnt working put it on reo |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1538 Registered: Aug-05 | I've got the specs. on the box SOMEWHERE... I'll have to measure tomorrow or something. The volume is ~4Cu. Ft. total. The VC config is 4 Ohm SVC. Works GREAT with an A8000T. |
Gold Member Username: Sploosh56Ohio Post Number: 1450 Registered: May-04 | vid looked sweet. mice system |
Gold Member Username: Cenus420 , 420 420 Post Number: 2011 Registered: Jan-05 | nice, man i really want to hear some assassins so i can compare them to my atlas's. by the sounds of it they should be very similar to each other. |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1540 Registered: Aug-05 | Just bumping this up here so I can put my RoE link on later...Whenever the video gets posted... |
