New member Username: DigitalgregPost Number: 1 Registered: Jul-06 | Hello everyone, im new here. I use to have a stereo system in my room but I removed it about 9 months ago b/c I didn't use it much (all my music is on the computer). Im considering putting it back in, but this time ill be hooking it up to the receiver. The receiver I have and plan on using is a Sony-De475. For the speakers im going to go with Athena AS-B2.2. I mostly listen to Punk, Ska, Goth, and Techno, high on the bass This system will be used for 90% music, eventually ill be hooking it to a TV/DVD. i was reading up on some subs and i came across the Athena AS-P4000 & AS-P6000. which would be a wiser sub to buy? velodyne VRP-1000 -OR- Athena AS-P4000 -OR- AS-P6000 If anyone has any suggestions for some subs, your input would be greatly appreciated. Thank you Greg www.digitalgreg.com |
Gold Member Username: Project6Post Number: 8679 Registered: Dec-03 | Listen to them and you will be able to determine that for yourself. You have pretty decent list of subs. Let your ears be your guide. Your receiver choice could be better, though. |
Bronze Member Username: Kinggimp82Post Number: 43 Registered: May-05 | whats ur budget for a sub? of those 3 id say go with AS-P6000. how much does that model go for anyway? two other good subs are the hsu stf-2 or svs PB10-NSD. but those run about $400. i own a hsu stf-2 myself. |
New member Username: DigitalgregPost Number: 2 Registered: Jul-06 | the 6000 goes for $249.95 + SH, but i can get it for $230 (SH included). im trying to stay close to $250 for the Sub. i was guessing the 6000 myself, its alittle to big foe me, but when i move it will be just right. thank you |
