New member Username: Renex242004Post Number: 3 Registered: Dec-05 | HELP PLEASE, i'm trying to find the speed sensor in my ford explorer 2002 for the GPS unit, please some one help me i need to know the color and the location, thank you so much my e-mail address is renex242004@msn.com. |
Silver Member Username: TjmutlowPost Number: 367 Registered: Sep-05 | top of firewall, passanger side, s/b grey/black. |
Silver Member Username: TjmutlowPost Number: 368 Registered: Sep-05 | In the pcm |
New member Username: My401kPSL, Florida Post Number: 5 Registered: Feb-06 | If you had a factory radio that had speed sensor for the volume, then you will have a connection in factory radio plug. Also, you might try to call Cruthfield techs, they may help in location. |
New member Username: OnebklynPost Number: 1 Registered: Jul-06 | Looking for the VSS (speed sensor) wire for a 2002 Ford Mustang GT. Would like to connect my GPS wire to get some accuracy on my AVIC N-1. Any help would be greatly appreciated. |
