New member Username: Buzz_akmPost Number: 1 Registered: Jul-06 | I desperately need to open a JBL DSC 200 subwoofer in order to get my cellphone out of it. Dont ask my how the cell got into the sub-woofer in the first place.....my 18 month kid put it in it. I removed all the screws from the outer boundary at the back of the woofer, but still not able to open it up. Pls help. The image for my subwoofer: http://www.futurehome.co.uk/scripts/prodView.asp?idproduct=422 |
Gold Member Username: NuckPost Number: 3669 Registered: Dec-04 | sorry to laugh, buzz. File it under WTF? |
Gold Member Username: Project6Post Number: 9019 Registered: Dec-03 | You cannot access the inside by removing the screws on the outer boundary. You have to remove the screws from where the speaker is attached. That is if it is a downfiring sub and the speaker can be seen. |
