Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 22 Registered: Jul-06 | I was at my car audio shop yesterday and proposed my idea which has been planned for 3-4 months now to the owner only to find out that I cant put a wall in my civic... I wanted to do 4 15"'s but now it looks like im going back to the boring bangin in the trunk. Probably going with 1 12" or 15" SSX... any other recommendations? |
Gold Member Username: Matt12490Benicia, California USA Post Number: 1121 Registered: May-05 | why did he say you couldnt do it? |
Gold Member Username: TheelfkeeperStockbridge, GA USA Post Number: 2490 Registered: Feb-05 | i've seen civics with walls... |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4341 Registered: Oct-05 | stever meade has 2 18s in a civic. |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 23 Registered: Jul-06 | supposedly u dont hear or feel the bass that well because there isnt enough space and appearantly u have to be a certain distance from the woofer to get the most out of it |
Silver Member Username: Troy81Tavernier, Fl Us Post Number: 647 Registered: Mar-06 | well, there might not be enough space, but itll still be good |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 24 Registered: Jul-06 | Should I do a Treo SSX 15"? |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3930 Registered: Aug-05 | BULL SH1T. this car hits 152dbs. and you sit RIGHT IN FRONT of the subs....and it gives me a damn headache. your telling me i can't hear that^^^^^^^ lol or feel it????? lol tell him he is stupid and you will spend your money at another audioshop. he told you no, b/c he was FU**ING lazy.....ppl at my shop have done that too. geeez |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 25 Registered: Jul-06 | MY place is stereorama... the top car stereo shop in all of florida. What subs are those? |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 26 Registered: Jul-06 | are those tsx's? |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3931 Registered: Aug-05 | SSX 12's |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 27 Registered: Jul-06 | tiiiight... Should I do those or a 2 12" RE MT's? |
Silver Member Username: TheweaselSteamboat springs, Colorado U.S. of A Post Number: 539 Registered: Mar-06 | those are 12's!? they look like at least 15's, lol. |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3932 Registered: Aug-05 | the SSX's will sound better they are a street bass subwoofer the MT's are designed for tone bursts. althought Isaac tweaked one out to sound halfway decent. |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 28 Registered: Jul-06 | Im just looking for something that will make my ears bleed and fit in my car... straight to rediculous bass. can you piece me something together for a 99 honda civic 2 door? looking around $1-2K for amps+subs. Ill take care of electrical upgrades. Any suggestions? |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3933 Registered: Aug-05 | get some DD 3515's and make a 6 cubic foot box.....with around 3,000watts. should be more than enough. |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 29 Registered: Jul-06 | how much are the 12"s or 15"'s? amp suggestions... |
Gold Member Username: CtmikeCt. Post Number: 1072 Registered: Feb-06 | 12" 3512 is $365, can't help ya with the 15". |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 30 Registered: Jul-06 | amps? |
Gold Member Username: RovinTrinidad & T... Post Number: 8519 Registered: Jul-05 | man u can put a wall into ANY ride - just last wk i saw 12 10s" in a lancer wagon & 16 10s in a "92 sentra , with a wall u lose ur back seat duh ! , but it will pound da hell outta u even 10s ..... |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3934 Registered: Aug-05 | get an Orion 2500D or 2 1500D's. |
Gold Member Username: CtmikeCt. Post Number: 1073 Registered: Feb-06 | don't know what your budget is, but hopefully i'll be getting 2 3512's soon and i plan to run each off either a kicker 1500.1 or a memphis 1500.1, or i might go cheap and get a nine.1 or kicker 1200.1, not sure though. |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 31 Registered: Jul-06 | any amp suggestions to power 2 12" DD3512's? |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 33 Registered: Jul-06 | ctmike...each 12 is 1600 watts rms... theres no way ud be able to power 2 12's decently with 1 1500 watt amp... |
Gold Member Username: CtmikeCt. Post Number: 1074 Registered: Feb-06 | one 1500 for each 3512. |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3935 Registered: Aug-05 | i think he means get one for each.....dunno though. lol |
Gold Member Username: RovinTrinidad & T... Post Number: 8521 Registered: Jul-05 | i seen ppl on DD froum putting 2000wrms daily on a DD3515 so ya i would say 1500wrms each should be no problem .... |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 34 Registered: Jul-06 | Would 2 Hifonics Bxi-2006d amps do the trick? |
Gold Member Username: RovinTrinidad & T... Post Number: 8525 Registered: Jul-05 | if u get each sub in 2ohms dvc ya that should be good - go 2 DD forum & read a few threads , u will get alot of good ideas from the DD users/experts there ..... |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 35 Registered: Jul-06 | where can i find one of those? |
Silver Member Username: Andysd03Post Number: 278 Registered: Jan-06 | http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4296 those will be freqin loud one would be all u need |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 39 Registered: Jul-06 | Which would have better SQL 2 DD3512's or 2 12" cerwin vega strokers? I want killer bass but I dont want it sloppy and off beat. |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3936 Registered: Aug-05 | HAHAHAHAHAHAHAHAHA the first choice would be your best bet.....some people...beg to differ on the stokers though....haha |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 42 Registered: Jul-06 | I dont get it, do the cerwin vega's suck???? are the DD's the best choice for the bass I'm looking for over all? |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 43 Registered: Jul-06 | can i get prices on the RE MT 12", 15" and the RE SX and XXX in the same sizes??... |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 44 Registered: Jul-06 | bump |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3937 Registered: Aug-05 | the only way to get a good deal on any RE stuff, is to go ebay. |
Gold Member Username: CtmikeCt. Post Number: 1076 Registered: Feb-06 | you have to call re and find out your local re dealer. i was told the msrp on a 12" xxx is $1,299, but the only re dealer in ct. says he'll sell them for $800. |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 46 Registered: Jul-06 | theres no RE dealers around me |
Gold Member Username: CtmikeCt. Post Number: 1077 Registered: Feb-06 | are there any u.s. amps dealers near you? if so then you'll probably be in luck since they own re. on the u.s. amp site there's lot's of dealers in florida, i'd try to see if any carry re. |
Bronze Member Username: Atllefty12Pinellas, Fla. Post Number: 47 Registered: Jul-06 | ok thanks |
Bronze Member Username: KravenbloodOhio Post Number: 77 Registered: Aug-05 | the strokers don't have that good of sq but get loud i have a 15 in a sealed box and its loud im going to port it sooner or later.., The stroker pro's suppose to have good sq...i don't know yet havent heard one and im a very indecisive person so i dont know if im going to get a stroker pro 15 yet... |
Bronze Member Username: ThebufromncRockwell, NC Post Number: 76 Registered: Jul-06 | the only Cerwin Vega Stroker to ever sound good is the one with the orange cap. Looks like this http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1942 but not this modile. It was made in the later 90's area. My buddy had one 18" in the back of his honda civic and was running 2 Kicker 1500.1d off it and damn was that one 18 a hell of a subwoofer. When i lived in West Virginia, (lol, dont believe the stereotypes about them West Virginians, lol) but anyways...We'd have crazy @ss parties in the Strip Mines and this Sub would be our DJ for the night. You could here this thing from like half a mile away. I wish i could get my hands on one. But from what i've heard the new strokers are a total let down from what they use to be and considering the price has gone up, i would never buy one. thats my opinion. go with the DD (think it was the 9915 series) cant remember, just heard them for the first time 3 days ago and man. That subwoofer can move like a champ. well good luck on the wall, and remember you can do anything you wanna do with the right amount of time and the Cream aka THE MONEY. Cause im rich B!tch. lol. jk |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3938 Registered: Aug-05 | the freq. response on that stroker is 40-200hz....that is quite the SQ range. lol |
